Results 1 to 10 of 20
Thread: Fuel gauge not working
    Oct 2017
    VIC
    Greetings
    I've had a hiccup with the fuel gauge once before - it stopped working for a day or so and then it worked Ok until recently.
    I took the pump out and in my haste thinking it's the gauge sender unit changed it. To my disappointment it's not it. After I soldered the new sender unit in (big mistake) I've measured the old one and it seems it was actually working Ok. When I say OK - when measured the ohm values were changing depending on the position of the floater.
    So now, I've got the new sender unit soldered in and still no gauge. Again I measured the resistance of the new unit and it also appears to have changing resistance.
    What gives?
    Fuel gauge not working-20230729s-jpg
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    What's the fault code in the cluster?
    That should give you a good idea what the issue is - is it short to ground or plus, is it resistance too high or too low
    Mornington Peninsula, VIC
    Measuring the resistance at the cluster and comparing it to the reading you get from the sender, you may have a break in the cable somewhere.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Oct 2017
    VIC
    Thanks guys,
    I'll have to hook up the vcds and post any suspicious fault codes - well, the ones which were not previously there .
    When you say 'resistance at the cluster' do you mean the 3 pronged terminal sticking out of the top of the pump? as well as the cable connected to it?
    Edit - the below are the photos of the pump cover and top of the pump. The 'insulation work' on the plug was done prior to me acquiring the vehicle.
    Fuel gauge not working-20230704_top-fpump-jpg Fuel gauge not working-20230704_fump0-jpg
    Oct 2017
    VIC
    My old laptop's battery unfortunately is u/s so it took me a while to hook up the extension power cord to get the scan going. But in any case here it is:
    Thursday,03,August,2023,11:07:17:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 20.12.0.0
    Data version: 20201124 DS322.0
    www.Ross-Tech.com
    Repair Order: 03082023
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 56 62 65
    69 72 76
    VIN: WVWZZZ3CZ6P178475 Mileage: 350510km-217796miles
    01-Engine -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Cannot be reached 1100
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Cannot be reached 1100
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Cannot be reached 1100
    25-Immobilizer -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Cannot be reached 1100
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Cannot be reached 1100
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    69-Trailer -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03H-906-032-BLV.clb
    Part No SW: 03H 997 033 K HW: Hardware No
    Component: P3.2 FSI-EU4 G00 2368
    Revision: --H11--- Serial number: VWZCZ000000000
    Coding: 0000175
    Shop #: WSC 00028 028 00001
    VCID: 356194D35C417F2CE0-8060
    1 Fault Found:
    012555 - Low Pressure Fuel regulation
    P310B - 004 - Fuel Pressure Outside Specification
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 157
    Reset counter: 255
    Mileage: 347856 km
    Time Indication: 0
    Date: 2023.05.19
    Time: 07:03:22
    Freeze Frame:
    RPM: 635 /min
    Load: 28.6 %
    Speed: 1.0 km/h
    Temperature: 72.0°C
    Temperature: 29.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 13.716 V
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 047 J HW: 02E 927 770 AE
    Component: GSG DSG 070 1154
    Revision: 04507000 Serial number: 00000602071105
    Coding: 0000020
    VCID: 1F4D567BCEBDD57C1A-804A
    No fault code found.
    Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0667165431
    Coding: 0046535
    VCID: 306FA5C7A3235A04B3-8064
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 142
    Mileage: 350068 km
    Time Indication: 0
    Date: 2023.07.18
    Time: 22:59:39
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000001002
    Shop #: WSC 01324 020 00200
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW46.rod
    VCID: 6ED37BBFB1970CF4E1-803A
    1 Fault Found:
    13701456 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 104
    Mileage: 350514 km
    Date: 2023.07.31
    Time: 11:08:28
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000003835219
    Coding: E1848F0700041A00000A00000F00000000085D435C0000
    Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 00028
    Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 011 1110
    Coding: 00208933
    Shop #: WSC 00028
    5 Faults Found:
    02394 - Parking Light Left Front (M1)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 143
    Mileage: 349923 km
    Time Indication: 0
    Date: 2023.07.16
    Time: 06:25:00
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    01496 - Bulb for Fog-Lamps; Left (L22)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 4
    Fault Frequency: 20
    Reset counter: 130
    Mileage: 348055 km
    Time Indication: 0
    Date: 2023.05.22
    Time: 18:01:00
    Freeze Frame:
    ON
    Voltage: 13.85 V
    ON
    ON
    OFF
    OFF
    OFF
    01500 - Bulb for Fog-Lamps; Right (L23)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 12
    Reset counter: 130
    Mileage: 348055 km
    Time Indication: 0
    Date: 2023.05.22
    Time: 18:00:00
    Freeze Frame:
    ON
    Voltage: 13.80 V
    ON
    ON
    OFF
    OFF
    OFF
    01517 - Control Module for Trailer/Towing Sensor (J345)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    Date: 2023.05.21
    Time: 13:28:00
    Freeze Frame:
    OFF
    Voltage: 13.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    01320 - Control Module for Climatronic (J255)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    Date: 2023.05.21
    Time: 13:28:00
    Freeze Frame:
    OFF
    Voltage: 13.25 V
    OFF
    ON
    OFF
    OFF
    OFF
    Oct 2017
    VIC
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
    Component: 17 AIRBAG VW8R 029 2521
    Revision: 10029000 Serial number: 003A3P1ZPVBF
    Coding: 0012599
    VCID: 2E53BBBFB9174CF4A1-807A
    Subsystem 1 - Serial number: 6332MSME0F5F0E3BY
    Subsystem 2 - Serial number: 6342MSME0F49367AQ
    Subsystem 3 - Serial number: 6351HTS64IKAP662E
    Subsystem 4 - Serial number: 6361HTS64IKQDAR21
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
    Component: J0527 0015
    Revision: 00005000 Serial number: 3C5953507P
    Coding: 0001111
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 007 0050
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
    Component: KOMBIINSTRUMENT VD1 4240
    Revision: X0033000 Serial number: 00000000000000
    Coding: 0007705
    Shop #: WSC 30081 959 88100
    2 Faults Found:
    00438 - Fuel Supply Sensor 2 (G169)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 349196 km
    Time Indication: 0
    Date: 2023.06.24
    Time: 20:27:36
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 138
    Mileage: 350289 km
    Time Indication: 0
    Date: 2023.07.26
    Time: 17:08:55
    Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3640P151190AC5
    Coding: FD82FF4F00020200F103
    Shop #: WSC 12345 123 12345
    VCID: 2F6DA6BBBE1D45FCAA-807A
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 C
    Component: HALDEX 4Motion 0108
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 2D51BCB3B41137EC98-8078
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 P HW: 3C0 959 433 P
    Component: IMMO 043 0364
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 377D9EDB464D8D3CF2-8062
    Subsystem 1 - Part No: 3C0 905 861 D
    Component: ELV 024 0370
    3C0905861D ELV 024 0370
    Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
    Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
    Component: Sitzverstellung 0701
    Revision: 00003000 Serial number: 00000000000000
    VCID: 2C57B1B78F0B3EE48F-8078
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
    Part No: 1K0 959 701 L
    Component: Tuer-SG 024 2462
    Coding: 0000951
    1 Fault Found:
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 3467A9D7573B6624D7-8060
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ46 RDK 043 0213
    Coding: 01910A0801860E76380694157008DFCE101800
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Subsystem 3 - Part No: 3C0 951 171 A
    Component: Innenraumueberw.002 0508
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 4
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    Date: 2023.05.21
    Time: 13:28:24
    Freeze Frame:
    Fault Priority: 4
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    Date: 2023.05.21
    Time: 13:28:24
    Oct 2017
    VIC
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
    Part No: 1K0 959 702 L
    Coding: 0000950
    VCID: 387F9DE74B538244FB-806C
    1 Fault Found:
    00132 - Outside Door Handle Illumination/mirror Light Passenger Side
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000012
    Shop #: WSC 30087 959 68769
    VCID: 21495083F8C9E38C2C-8074
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3AD 035 190 A HW: 3AD 035 190 A
    Component: RCD510USBRVC 003 0003
    Revision: -----001 Serial number: VWZ4Z3P8053234
    Coding: 01000425040010
    Shop #: WSC 00079 790 12345
    VCID: 2B55B2AB4A0539DC86-807E
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 347908 km
    Time Indication: 0
    Date: 2023.05.20
    Time: 14:47:44
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2432
    Coding: 0000144
    VCID: 3365AACB5235611CCE-8066
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0391
    Coding: 0161210
    Address 69: Trailer Labels: 1K0-907-383-V1.clb
    Part No SW: 1K0 907 383 HW: 1K0 907 383
    Component: ANHAENGERELEKTR 003 0020
    Coding: 0000001
    VCID: 6ADB77AF457FE0D4BD-803E
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    Address 76: Park Assist Labels: 3C0-919-283.lbl
    Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
    Component: Parkhilfe 8-Kan 004 0011
    Revision: 00004000 Serial number: 82930602501458
    Coding: 0011014
    VCID: 285F4DA79BF312C46B-807C
    End-------------------------(Elapsed Time: 02:49)--------------------------
    Code:
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 349196 km
    Time Indication: 0
    Date: 2023.06.24
    Time: 20:27:36
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 138
    Mileage: 350289 km
    Time Indication: 0
    Date: 2023.07.26
    Time: 17:08:55
    I would guess there is an open circuit somewhere. Check out this wiring diagram; I would be checking the plug at the cluster a 36-pin and checking its connectivity to the 3-pin connector at the tank.
    Fuel gauge not working-fuel-jpg
    Oct 2017
    VIC
    Quote Originally Posted by MIG View Post
    Code:
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 349196 km
    Time Indication: 0
    Date: 2023.06.24
    Time: 20:27:36
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 138
    Mileage: 350289 km
    Time Indication: 0
    Date: 2023.07.26
    Time: 17:08:55
    Thanks for the information MIG
    I'm hoping it's not the 'new' sender unit I installed (seems unnecessarily) about a week ago. I did check it's resistance prior to fitting and it appeared to be working Ok. That 3 pronged plug on the top of the pump seem OK too - from memory there was a continuity between. at least, 2 terminals? However, if all 3 have to have continuity then something is NQR. I'll have to re-check this again.
    As to the T36 connector - where exactly does it plug in? Must be somewhere at the back of the cluster display? So, this could be 'the cluster' you guys were talking about. If so, I'd have to research how to take the cluster out to check that connector.
    Maybe go back to the basics before pulling the cluster.
    Check the three pins first.
    One pin should be to ground (pin1 brown\blue); one should be a reference voltage and the other the sense wire for the sender.
    Maybe look under that tape mess
