Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Fuel gauge not working
    There is a useful post on the Ross Tech forum which explains the differences between short to plus, short to ground faults etc:
    Testing - Open Circuits, Short to Ground or Positive, etc.... | Ross-Tech Forums
    Oct 2017
    VIC
    Thanks - it'll be tonight's reading
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    Oct 2017
    VIC
    Today I've tried troubleshooting this
    1 - checking the plug (as below - ignition on) resulted in 0.9V between the connector 2-3 blue purple/white wire and 0V on brown/blue stripe earth? wire.
    2 - Testing for Short to Ground (as per Ross Tech) produced battery voltage 0.9V
    3 - Testing for Short to Positive (as per Ross Tech) showed 12V.
    There does not seem to be a specific fuse to cover fuel gauge that I could find? but is there any way to power up and check the gauge itself?
    Fuel gauge not working-20230806-jpg
    Oct 2017
    VIC
    An update (sort of) - I've had one of the TTY guys have a look at this for me. Despite swapping Fuel Pump Controller (from R36 I think it was), both fuel sender units he was unable to pinpoint where the fault is. In any case the fuel sender units (in the car) were testing a moving resistance and the fuel gauge itself needle could be moved using the VCDS so unlikely indicating a mechanical fault to the gauge itself.
    Jan 2020
    Sydney,NSW
    Hi,
    Maybe a longshot...
    I had a fuel supply issue a couple of years back with a low fuel pressure sensor fault. Long story short, once the sensor was replaced and couple of other bits, all the hardware was good, save for the gauge measuring. Turned out the coding for the gauge was corrupted. The tank characteristic curve for the left tank (from memory) was missing and the gauge 'code' could only see one tank. Therefore, fuel load was incorrectly calculated (not helpfully, above what was in the tanks) so just over half full on the gauge was empty tanks.
    Perhaps check the tank characteristic curves in the coding for your dash. (I note mine is a later dash than yours)
    Quote Originally Posted by Old Navman View Post
    R36 Wagon MY2010.5: Biscay Blue| Dynaudio and Nav| RVC| VW tow bar|
    Mod highlights:
    ECU and DSG Tune| 3AA CCM and 7N0 Gateway| 3D colour MFD| MIB2 retrofit and 7N0 RVC| Quad LED tail, brake and indicator rings| Zimmermann Sportbrake rotors, composite pads| TPMS High| 2Q0 Blind Spot and RCTA| B8 rearview mirror|
    Mornington Peninsula, VIC
    I am guessing you have the older red screen cluster?
    With the correct plug-and-play adaptor, I think you can just drop in a B7 cluster.
    If you don't mind coming down this way, I have a spare B7 cluster and the tool to correct the ODO
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Yes you can install a UDS cluster. You'll lose the comfort and lighting menus, but they can be controlled indirectly with VCDS.
    Need a 32 to 36 pin adapter and the front trim piece which is a different shape.
    Oct 2017
    VIC
    Quote Originally Posted by MMR36 View Post
    Hi,
    Maybe a longshot...
    I had not tinkered with this coding at all unless it got corrupted 'by itself' but I will try to have a look at those details next time I've got VCDS hooked up.
    Oct 2017
    VIC
    Quote Originally Posted by MIG View Post
    Correct, the reddish display. Thanks for your offer, I might just take you up on that one of these days. Incidentally, I was at Mordi about 2 weeks ago could have popped in for a chinwag. How do I contact you - can you PM me your mobile number? Cheers
    Oct 2017
    VIC
    Yes you can install a UDS cluster. You'll lose the comfort and lighting menus, but they can be controlled indirectly with VCDS. Need a 32 to 36 pin adapter and the front trim piece which is a different shape.
    I gather this will work with my existing Canbus modules, etc. Not that I have UDS clusters laying around but I might just have to get one if at the end of the day I can't get this working. I guess I'm being mindful of how much I have to spend versus how much the car is currently worth which is not a lot. It's been suggested that I simply carry a jery can in the boot.
