Results 1 to 9 of 9
Thread: Fault Codes
    May 2017
    Fault Codes
    Has anyone else had this code with there v6 highline?
    Fault code - 02248, Clutch Operating Angle Fault N375
    With bit of research it appears I may be up for a haldex controller
    2012 MY12.5 V6 Passat
    May 2017
    So it is the case.
    The car has a good service history - always at volkswagen apart from the last service.
    I am the third owner
    Is it worth pursuing through VW, granted the car has just clicked over 5 years on
    it's delivery date?
    Is this a generic OBD2 scanner output? Or from a VW specific tool like VCDS?
    May 2017
    Not sure about the first scan but the second scan today
    was at a specialist who I assume would be using VCDS cable,
    who confirmed a new controller in the region of $2600 from VW
    I'll defer to those more knowledgeable than me but it might be worth trying to just change the Haldex oil and filter and see if that resolves the issue.
    Mar 2014
    Melbourne, Vic
    Either what Kamold has recommended or you can pick up the haldex controllers on eBay.
    I'll have my original controller available soon as it's being replaced with a HPA controller this week at some stage....
    May 2017
    Quote Originally Posted by rjt86 View Post
    Thanks for the offer. I managed to find one locally at the wreckers, should be fitted this Friday.
    Mar 2014
    Melbourne, Vic
    Cool keep us posted on how it goes
    May 2017
    Yes, looking forward to the lack of wheelspin!
