Results 1 to 10 of 10
Thread: Fault Code B10A915: Activation A/C compressor, Open circuit/short circuit to B
    Mar 2014
    melbourne VIC
    Hi All,
    I replaced the battery in my 2013 Passat 130TDI two days ago. Today we have warm weather and I used the cooling for the first time since the battery swap. I was only getting warm air. My OBD2 scanner is giving me the following fault code:
    9480469
    Could this be related to the battery replacement? I.e. is it possible a reset of some sort might fix the issue?
    Mornington Peninsula, VIC
    Check out B10A9 - Ross-Tech Wiki
    and Tis’ the HVAC Season | Ross-Tech Forums
    The connector on the compressor is pretty easy to get to; if you take off the skid plate, you should be able to see it without jacking up the car.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Mar 2014
    melbourne VIC
    Thanks MIG. I will have a look at your links.
    I forgot to mention that the car had been sitting in the carport for 5 weeks while we were on holiday (hence the dead battery), which potentially brings a refrigerant leak into the picture.
    Check cabling: I have heard many stories of rodents getting to cables when cars are parked for a while.
    Fuses would also be a good start. Did you jump-start the car at all?
    Using a test lamp at the compressor valve, if you have one, would be a quick test.
    Possible Causes
    Fuse(s) faulty
    Wiring and/or Connector(s) from/to Compressor Regulating Valve (N280) faulty
    The wrong 2-wire electrical connector is plugged into the Regulating Valve (N280)
    Heating/Climate Control Module (J301) faulty
    Mar 2014
    melbourne VIC
    Thanks again MIG. All fuses seem to be good.
    I ran the car in the driveway this morning and the AC worked OK. I got cold air when I selected MAX AC. And the aluminium pipe that comes from the compressor was cold. I stopped the engine and tried the AC again. This time it was blowing ambient air and the aluminium pipe was warm. The same error code was present.
    So it seems my problem is intermittent. I thinks it's a job for the experts.
    Oct 2017
    VIC
    Quote Originally Posted by jack in oz View Post
    Perhaps it's the compressor control valve? You can read up on this in this post here:
    Secret air conditioning sequence? R36 2008 (vwwatercooled.com.au)
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    Mar 2014
    melbourne VIC
    Quote Originally Posted by Old Navman View Post
    Thanks. Hopefully it is the RCV and not the compressor. When my new car arrives in a couple of months I'll be selling this car. I'll be very cranky if I have to spend $1500 on a new compressor when I'm about to sell it. Especially after I just spent $565 on a thermostat and $350 on a battery.
    Oct 2017
    VIC
    Yeah, it sucks. If the temperature oscillates between warm and cold it could just be the valve. In any case, changing the compressor control valve would be the cheapest option because it would involve a relatively small outlay in comparison to the other choices.
    Mar 2014
    melbourne VIC
    Thanks, will get that done.
    Mar 2014
    melbourne VIC
    I rang two places. Both advised me to replace the compressor and quoted just under $1000. I said I just wanted the valve replaced. One of them agreed to do that for $450. Job done. Now my AC is working again. Thanks to Old Navman for pointing me in the right direction.
