After speaking with Alba European, it appears the oil pump module consists of separate parts with their own part numbers (oil pump, balancing shaft, hex carrier etc) - some are available genuine and others aftermarket. VW only wanted to replace the whole (very expensive) module.
I've ordered ~$200-300 in parts from the UK, which are due to arrive next week. I'll update this thread with details in case anyone else finds themselves in the same situation.
