Engine swap options 125TDI Passat (BMR)
The oil pump balance shaft module needs replacing on our 2008 125TDI Passat. There was no other engine damage, but VW pricing for that part (03G 103 295 AK) is almost as much as the car's value! (fail VW...) - I can get the part from overseas for less than ~1/3 of the price, but it involves long wait times...
It seems this is an engineering fault and common problem on the BMR engines within 130,000-200,000 kms.. It's likely to be cheaper just to do an engine swap, but it's proving impossible to find a 2nd hand BMR engine with low kms.
So, does anyone know if there are compatible engine codes out there that would be suitable for a swap?
It looks like a CBBB engine is often listed alongside the BMR - would this be an option for an engine swap?
We have a replacement car (Tiguan) arriving in a couple of months, so open to ideas...
