Results 1 to 10 of 15
Thread: Engine swap options 125TDI Passat (BMR)
    Feb 2014
    The oil pump balance shaft module needs replacing on our 2008 125TDI Passat. There was no other engine damage, but VW pricing for that part (03G 103 295 AK) is almost as much as the car's value! (fail VW...) - I can get the part from overseas for less than ~1/3 of the price, but it involves long wait times...
    It seems this is an engineering fault and common problem on the BMR engines within 130,000-200,000 kms.. It's likely to be cheaper just to do an engine swap, but it's proving impossible to find a 2nd hand BMR engine with low kms.
    So, does anyone know if there are compatible engine codes out there that would be suitable for a swap?
    It looks like a CBBB engine is often listed alongside the BMR - would this be an option for an engine swap?
    We have a replacement car (Tiguan) arriving in a couple of months, so open to ideas...
    You're going from a PD to a common rail there. So you'd need the ECU for a start, that would either need to be made immo off, or immo matched to your CCM.
    Then you'll need all the engine side wiring harness, and there may also be wiring changes needed back to the body (would need to carefully study the wiring diagrams of both.)
    If you're looking for an easy cheap swap I would guess this might not be it.
    That's without doing any checks on the wiring etc, just thoughts.
    If it's something you really want to do I'm sure it's possible but before buying anything I'd be spending some time checking over the wiring diagrams.
    Feb 2014
    Yeah, I'm thinking the car is essentially scap now.
    It's really disappointing to buy a new VW, take great care of it, spending loads of cash each year on genuine parts/maintenance, just to have the engine die at only 160k...
    The car is essentially "written off" because VW want over $6K (+$3K labour) for an oil pump shaft that failed due to poor engineering... oil pumps should outlast most engine components - TBH it makes me question the confidence I had (and would share) in VW engineering...
    Anyhow, rant over... probably a lesson that VWs don't last and to replace them before they get too old. If you were cynical, you might think that they are designed that way to generate maximum profits...
    Bws swap it
    Sent from my SM-G781B using Tapatalk
    Feb 2014
    Bws swap it
    What's a BWS swap?
    R36 motor
    Feb 2014
    R36 motor
    Oh, that would be cool. Probably more trouble/cost than it's worth on an old 125TDi I'm guessing.
    You can buy the balance shaft locally for $1800. This place says they have one in stock although id be calling and checking if that is accurate. Balance Shaft Module / Oil Pump for 2.0TDI - 03G103295AK – Boosted Autosports PTY LTD
    VAGParts in Sydney can supply them but it says up to a 4 week lead time: Balance Shaft Module / Oil Pump for Volkswagen & Audi 2.0 TDI - 03G103
    – VAGPARTS Australia
    Feb 2014
    Thanks Lucas_R =)
    I tried contacting Boosted Friday, but haven't received a response (web and facebook, couldn't find a phone number). There are a couple of genuine options on eBay from Germany and Hungary too, shipping takes ~4 weeks (hopefully).
    This may be an option. The part costs $1,800 (or ~$1,100 w/ shipping internationally), one dealer said $1,500 labour and another $3,000.
    So $2,600 to $4,800 approx.. at $2,600 it's worth it, at $4,800 it's questionable (not sure what I'd get from the wreckers, but probably not much)..
    While we're working this one out (could take weeks), we're down to 2 cars, so I'm looking for a replacement anyway. Test drove a 2nd hand Arteon today, more sedate than my R36 (same performance on paper), but much more comfortable/modern.
    Seeing you are in Brisbane, id be giving Alba European a call. He has a very good reputation for all things VW/Audi.
    He might have a contact for sourcing the part and can no doubt give you info and/or a quote on the installation side of things:
    Alba European - Home
