Results 1 to 10 of 13
Thread: Electric Park Brake Fault
    EPB decided to not disengage this morning.
    Restarted the car and it released ok.
    I have the following fault codes against the controller:
    Code:
                    Address 53: Parking Brake       Labels: 5N0-907-801.clb
    Control Module Part Number: 3C8 907 801 A    HW: 3C8 907 801 A
      Component and/or Version: J540 EPB3  VW-10498 0003
               Software Coding: 0000057
                Work Shop Code: WSC 05311 000 00000
                          VCID: 28540A039BFA477E16-807C
    5 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
                012 - Electrical Fault in Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00111100
                        Fault Priority: 1
                        Fault Frequency: 3
                        Reset counter: 109
                        Mileage: 84789 km
                        Time Indication: 0
                        Date: 2009.14.03
                        Time: 14:40:09
                 Freeze Frame:
                        Voltage: 12.30 V
                        Count: 10
                        Speed: 0.0 km/h
                        Hex Value: 0x12E1
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 109
                        Mileage: 85073 km
                        Time Indication: 0
                        Date: 2009.14.12
                        Time: 08:28:58
                 Freeze Frame:
                        Voltage: 13.50 V
                        Count: 30
                        Speed: 0.0 km/h
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 109
                        Mileage: 85073 km
                        Time Indication: 0
                        Date: 2009.14.12
                        Time: 08:28:58
                 Freeze Frame:
                        Voltage: 13.50 V
                        Count: 31
                        Speed: 0.0 km/h
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    16366 - Control Module - Internal Malfunction; CPU 2
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 109
                        Mileage: 85073 km
                        Time Indication: 0
                        Date: 2009.14.12
                        Time: 08:28:58
                 Freeze Frame:
                        Voltage: 13.50 V
                        Count: 41
                        Speed: 0.0 km/h
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    16352 - Control Module - Electrical Error
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 109
                        Mileage: 85073 km
                        Time Indication: 0
                        Date: 2009.14.12
                        Time: 08:28:37
                 Freeze Frame:
                        Voltage: 13.60 V
                        Count: 42
                        Speed: 0.0 km/h
                        Hex Value: 0x12F1
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Just wondering if anyone else has had a similar fault and could confirm that simply replacing the control module resolved it?
    Thanks
    My EPB would not disengage on my 07 Passat a few years ago while in a shopping center car park, called the RAA as I knew it would need a tow. They send out a chap to first inspect the car, asked where my fuses are, I opened my drivers side door, opened that panel, open the passenger side door, open that panel then open the bonnet to show the fuses there, which ones do you want I asked? Very shortly after that he arranged for a tow. Mine simple needed a new EPB, but I was told that later models also require a computer upgrade for the EPB program.
    Peter.
    Dec 2008
    Sydney/Canberra
    Pop the button out, and look at the part number on it.
    If it ends in BREH, replace it with the superceded part and see how you go.
    Thanks Umai Naa, its a 3C0927225B.
    I've ordered a new switch, and a superceding EPB module 3AA907801J.
    Hopefully it can stay together until parts arrive from OS, as I wasn't prepared to pay $1k for the module and $116 for the switch...I'll take out some roadside assistance though just in case.
    Sep 2005
    Maroubra Beach
    I had this issue and the new switch fixed it.
    But if you drive off with it on it releases automatically anyways.
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
    The fault codes concern me, so I think I'll do both. Although the control module is under the centre console which is apparently a big job to remove. Will do the switch as soon as it arrives.
    Sent from my HTC One_M8 using Tapatalk
    Dec 2008
    Sydney/Canberra
    Definitely do the switch first, clear the codes, and see how you go.
    I think I've only ever come across one where the switch didn't completely fix it, but it was real early B6.
    Thanks will do. Have a second hand controller coming from a CC so will use that if needed, didn't break the bank.
    Mar 2016
    Qld
    Quote Originally Posted by Umai Naa!! View Post
    I've got a similar intermittent problem. How do you pop the button out?
    Dec 2008
    Sydney/Canberra
    Pull the end cover off the dash, and push it out from the back.
