Code:------------------------------- Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb Part No SW: 03H 906 032 AM HW: 03H 906 032 AB Component: R3.6-FSI-EU4 G 3488 Revision: 5GH04--- Serial number: VWZCZ000000000 Coding: 0000175 Shop #: WSC 05311 000 00000 VCID: 6DDA3B177498A22BA0-8038 3 Faults Found: 005715 - Please check DTC Memory of ABS Controller P1653 - 004 - Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:48:29 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 50.0°C Temperature: 45.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 049508 - No Communications with HVAC Control Module (J301) U0164 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:48:30 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 50.0°C Temperature: 45.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 005715 - Please check DTC Memory of ABS Controller P1653 - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:48:32 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 50.0°C Temperature: 45.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V Readiness: 0110 0101 ---------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Part No SW: 3C0 614 109 P HW: 3C0 614 109 P Component: J104 C4 440 V2 0011 Revision: --025--- Serial number: 00000786146748 Coding: 0001439 Shop #: WSC 05311 000 00000 VCID: 2B5EF50F8A0C6C1BFE-807E 5 Faults Found: 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation 01542 - Yaw Rate Sensor (G202) 005 - No or Incorrect Basic Setting / Adaptation 01423 - Lateral Acceleration Sensor (G200) 005 - No or Incorrect Basic Setting / Adaptation 01279 - Longitudinal Acceleration Sensor (G251) 005 - No or Incorrect Basic Setting / Adaptation 00810 - Sensor 1/2 for Brake Pressure 005 - No or Incorrect Basic Setting / Adaptation ---------------------------- - Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 E HW: 3AA 907 801 E Component: J540 EPB4 VW-55183 0007 Revision: H18 Serial number: 00000000155378 Coding: 0021057 Shop #: WSC 05311 000 00000 VCID: 336EED6F523C34DBB6-8066 8 Faults Found: 02844 - Lamp for Automatic Parking Function 009 - Open or Short to Ground Freeze Frame: Fault Status: 01111001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:50:21 Freeze Frame: Voltage: 11.80 V Count: 81 Speed: 0.0 km/h Hex Value: 0x1250 Hex Value: 0x0001 Hex Value: 0x0101 02430 - Left Parking Brake Motor (V282) Resistance to Movement 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:50:45 Freeze Frame: Voltage: 10.40 V Count: 23 Speed: 0.0 km/h Hex Value: 0x1251 Hex Value: 0x0001 Hex Value: 0x0808 02431 - Right Parking Brake Motor (V283) Resistance to Movement 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:50:45 Freeze Frame: Voltage: 10.40 V Count: 24 Speed: 0.0 km/h Hex Value: 0x1251 Hex Value: 0x0001 Hex Value: 0x0808 03263 - Functional Restriction 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 164 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:51:11 Freeze Frame: Voltage: 11.80 V Count: 135 Speed: 0.0 km/h Hex Value: 0x1240 Hex Value: 0x0001 Hex Value: 0x0404 01316 - ABS Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01111101 Fault Priority: 2 Fault Frequency: 7 Reset counter: 164 Mileage: 22159 km Time Indication: 0 Date: 2015.06.08 Time: 00:09:40 Freeze Frame: Voltage: 10.30 V Count: 69 Speed: 0.0 km/h Hex Value: 0x12E0 Hex Value: 0x0001 Hex Value: 0x0202 03200 - Switch for Electric Parking Brake (E538) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 204 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:52:11 Freeze Frame: Voltage: 11.80 V Count: 9 Speed: 0.0 km/h Hex Value: 0x1242 Hex Value: 0x0001 Hex Value: 0x0404 01087 - Basic Setting Not Performed 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 164 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:37:36 Freeze Frame: Voltage: 11.90 V Count: 41 Speed: 0.0 km/h Hex Value: 0x1250 Hex Value: 0x0001 Hex Value: 0x0101 01279 - Longitudinal Acceleration Sensor (G251) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01110101 Fault Priority: 1 Fault Frequency: 1 Reset counter: 164 Mileage: 87444 km Time Indication: 0 Date: 2016.05.23 Time: 10:37:36 Freeze Frame: Voltage: 11.90 V Count: 99 Speed: 0.0 km/h Hex Value: 0x1250 Hex Value: 0x0001 Hex Value: 0x0101
