Results 1 to 10 of 14
Thread: Electric mirrors only working in one direction B6
    Dec 2007
    ivanhoe vic
    Hi weird issue with both my Lhs and rhs mirror they only adjust to the right now from the control on the drivers door not up down or to the left and now the drivers one is stuck all the way to the right. Nothing happens at all when I try the other directions.
    Most likely the switch? Last time I used it the mirror heating still worked.
    B6 Passat Wagon No KESSY
    Dec 2007
    ivanhoe vic
    Anyone?
    Have VCDS? If so any faults?
    You can get a replacement switch very cheaply online to rule that out.
    Dec 2007
    ivanhoe vic
    No don't have it the other weird thing is that occasionally I am get the parking brake warning light but the parking brake is working fine? Thanks for the reply any tips on where to order the switch from?
    Replace the park brake switch. Easy 5 min job:
    http://www.aliexpress.com/item/Origi...241665405.html
    I replaced all the switch gear with these satin chrome tipped ones:
    Buy Products Online from China Wholesalers at Aliexpress.com
    Dec 2007
    ivanhoe vic
    thanks mate much appreciated any tips for replacement or they should just pop out?
    Park brake switch: pop off end of dash panel to reveal the fuse box.
    Switch is held in with top and bottom metal spring clips. So just push the switch from behind the dash to pop out, then unplug connector. Install new one.
    Window switches panel: just pops up with a trim tool, see this video for details https://www.youtube.com/watch?v=Em0TMdrPiu4
    Dec 2007
    ivanhoe vic
    Awesome thanks mate so just buy a set of trim tools locally?
    Yeah you can get them from Repco or supercheap, or just order online as well if you want to save a few bucks given you'll have to wait for the switches anyway.
    Dec 2007
    ivanhoe vic
    I see SCA have one as do Autobarn...
