According to Dr Google it looks like it might have to be coded.
01044 - Ross-Tech Wiki
C1044 Right Rear Tone Wheel Performance - Obd2-code
I just recently changed a right rear wheel speed sensor on my 2010 upgrade passat tdi 2ltr highline and it’s now saying error code 1044 which with vcd it’s a coding error for control module relating to tyre pressure monitoring system mechanical issue, how do I fix this and how do I re code it.
Thanks I’ve done the research, I will run another test for codes after I’ve driven it to get the battery powered again and system reset itself after driving it for a little bit. If not I will take to my independent VW mechanic and get them to have a look at it but I believe I’m on the right track as I’m no mechanic just DIYer to some degree.
Check THIS thread out - some of the coding could well be also relevant to your vehicle.
2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
