Results 1 to 5 of 5
Thread: Dtc 1044
    Apr 2021
    Gold coast
    Lightbulb Dtc 1044
    I just recently changed a right rear wheel speed sensor on my 2010 upgrade passat tdi 2ltr highline and it’s now saying error code 1044 which with vcd it’s a coding error for control module relating to tyre pressure monitoring system mechanical issue, how do I fix this and how do I re code it.
    According to Dr Google it looks like it might have to be coded.
    01044 - Ross-Tech Wiki
    C1044 Right Rear Tone Wheel Performance - Obd2-code
    Apr 2021
    Gold coast
    Coding issue
    Thanks I’ve done the research, I will run another test for codes after I’ve driven it to get the battery powered again and system reset itself after driving it for a little bit. If not I will take to my independent VW mechanic and get them to have a look at it but I believe I’m on the right track as I’m no mechanic just DIYer to some degree.
    Oct 2017
    VIC
    Check THIS thread out - some of the coding could well be also relevant to your vehicle.
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    Apr 2021
    Gold coast
    Quote Originally Posted by Old Navman View Post
    Thanks mate it’s seems like an interesting read and discover under the hood haha it’s activated but saying it may be a a reduced running and usage so I have to take it to a mechanic soon as I have another unrelated issue that needs fixing as well.
    Thanks
