Results 31 to 35 of 35
Thread: DQ500 retrofit
  1. #31
    Mar 2024
    Miami, FL USA
    VW MK5 R32 turbo
  2. #32
    Best bet should be using PQ RSQ3 software. Will need to be modified by a tuner for correct ratios for your gearbox etc.
    You'd need PCMFlash with direct TCU harness and Scanmatik Pro 2 interface to flash PQ software and eeprom.
    Ideally also ODIS Engineering (which can use SM2 in passthru) to flash parameters and possibly different software versions if needed.
  3. #33
    Mar 2024
    Miami, FL USA
    Thank you 👍
  4. #34
    But again, I've never done this (flashing MQB mecha to PQ) and haven't seen it documented anywhere (also haven't looked, so would recommend trying to find it).
    Have flashed plenty of other MQB hardware modules to the PQ software versions, but never anything as expensive as a mechatronics. And certainly not a module that contains immobilizer data.
  5. #35
    Apr 2021
    nice thread, alot of time and work has gone into this build, I've just completed a tiguan dq500 mqb to s3 cjx mqb,
    with regards to the dq500 pq/mqb flashing back and forth, yes you can to a certain extent. if the mechatronics is the original made in germany 711c/711g it can support both pq and early mqb vehicles. if you have the newer 0de/ogc 711g/h this can only support mqb vehicles. i flash them daily for transmission shops and convert them to dq381/dq500 depending on the vehicle.
    flashing via odis/pcmflash/flex/whatever is possible and immo only matters when you are flashing via obd.
