Results 1 to 5 of 5
Thread: Dq250 mechatronic plug leak
    May 2023
    Hi. How common is mechatronic connector/plug to leak fluid out of the pins/harness? Is this a bad sign? Can it be repaired?
    There is a breather hole in the middle of the plug.
    Unless there are any fault codes or problematic behaviours, just clean it off.
    Was the DSG overfilled at last service?
    If the proper level procedure isn't used it's easy to over fill.
    May 2023
    Hi. No fault codes. I will take the air box out to gain access and use some contact cleaner. Should I unplug it and clean inside it? Thanks.
    May 2023
    Update: I've cleaned it off and the leak has come back again. No error codes or drivability issues thus far. A little concerning still.
    May 2023
    Quote Originally Posted by rgh0 View Post
    3 posts from this guy the first 2 of which were meaningless short comments and this this one an add for online gambling. I say its a BOT ?
    Yep annoying stupid bots
