Results 1 to 4 of 4
Thread: The dog ate my key Passat B7 118TSI
    Apr 2024
    Kurrajong
    The new pup decided that our B7 Passat 118TSI key looked tasty and gave it a pretty good chew to the point where it would no longer fit in the key slot
    We dismantled the key and were able to remove the battery printed circuit board which did not appear to have any damage.
    We purchased a new key shell via EBay and installed the original board and battery in the replacement shell.
    Lock and unlock work fine, However when the replacement key is in the key slot I am met with the Message IMMOBILISER ACTIVE/
    Spare fob works fine.
    Any suggestions as to why the replacement key won't work or suggested fixes will be most appreciated.
    Found this video on line
    Volkswagen Immoblizer active no crank not start easy solution. - YouTube
    Can anyone confirm that this works?
    Mornington Peninsula, VIC
    There is a little glass “pill” in the middle section of the plastic case, this is the RFID chip the immobiliser uses to auth the key. You should be able to move it from the old case to the new one, just be careful they are glass.
    I will upload some pics of the location when I get home.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Here is the pic of what the transponder looks like, it will need to be moved over to the new case.
    The dog ate my key Passat B7 118TSI-img_0591-jpg
    The dog ate my key Passat B7 118TSI-img_0592-jpg
    Apr 2024
    Kurrajong
    Life Saver. Followed your advice and $14 EBay replacement case and old interior works perfectly.
