There's a thread in the Golf Mk5 & Jetta section discussing the use of a disc brake calliper rewind tool when changing the rear brake pads.
Which tool needed for rear caliper piston retraction?
Does anyone know if this is necessary or helpful when changing the rear pads on a B6 Passat?
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
Yes. I have EPB and access to VCDS.
