Results 1 to 10 of 48
Thread: Custom R36 Cold Air RAM intake - Almost $0 DIY or small fee to get it done
Threaded View
Elmura Custom R36 and Passat CC Cold... 21-04-2015, 11:22 PM
snerlo Hmmm, Bit hard to follow... 22-04-2015, 08:19 AM
Elmura I've just installed the app... 22-04-2015, 06:56 PM
gldgti A note on maf grilles - ... 23-04-2015, 08:04 AM
Elmura To be sure. Are you... 23-04-2015, 08:46 AM
Elmura In my post, I've shown a link... 23-04-2015, 08:47 AM
gldgti Not so much correcting you as... 23-04-2015, 08:49 AM
Elmura It's an interesting... 23-04-2015, 10:25 AM
gldgti My allroads maf only has the... 23-04-2015, 10:33 AM
gldgti So after a bit of reading, it... 23-04-2015, 05:54 PM
eurobahn5 Cold air intake 26-04-2015, 04:33 PM
Elmura gldgti - I searched that... 23-04-2015, 07:29 PM
gldgti Quite right too. Search... 23-04-2015, 08:22 PM
Elmura Great stuff. Some questions:... 26-04-2015, 07:44 PM
eurobahn5 Hi, my R36 is the old 2008,... 26-04-2015, 09:39 PM
snerlo Eurobahn, I have an 08 model... 28-04-2015, 04:44 PM
Elmura Is there any difference betw... 28-04-2015, 05:13 PM
eurobahn5 I bought my BMC filter for... 28-04-2015, 08:13 PM
Elmura I just examined a GruppeM... 02-05-2015, 07:27 AM
kamold Colour me interested in the... 02-05-2015, 09:34 AM
XXX-1.8T What about the one Forge... 04-05-2015, 09:02 AM
Elmura Updated on next post 04-05-2015, 12:16 PM
Elmura Thanks for pointing this one... 04-05-2015, 12:19 PM
XXX-1.8T They use K&N panel filter 04-05-2015, 01:32 PM
Elmura Update: Further proof... 08-05-2015, 09:41 PM
gldgti That's not really proof it's... 09-05-2015, 01:30 PM
Elmura Here are some Diagrams to... 15-05-2015, 11:30 PM
esskayy Hi Elmura, you have pm 18-05-2016, 11:24 AM
xR360 Hi Elmura & fellow admirers,... 19-11-2016, 12:56 PM
dvkent Might have to try this mod on... 19-11-2016, 03:45 PM
Elmura Hi guys, Been a while since... 19-11-2016, 09:13 PM
dvkent Wow. I have also deleted... 20-11-2016, 11:34 AM
ZR36 I would have to say that VW... 20-11-2016, 03:34 PM
Mysticality Volkswagen has done hours and... 20-11-2016, 03:42 PM
Greg Roles They do indeed. Then the... 20-11-2016, 06:30 PM
Elmura I did some of the work so... 20-11-2016, 08:53 PM
xR360 #Elmura Haha, keep up the... 21-11-2016, 06:38 PM
Elmura The type of exhaust valve I... 16-12-2016, 08:25 AM
eurobahn5 I am also about to install... 21-11-2016, 07:14 PM
ZR36 Aren't you selling your... 24-11-2016, 08:21 PM
Passat R36 had a quick look at the... 23-11-2016, 10:00 AM
eurobahn5 http://www.vwwatercooled.com.a... 24-11-2016, 03:58 PM
Elmura I did consider this also and... 13-12-2016, 09:26 PM
kamold Can't wait for the video!! 24-11-2016, 04:30 PM
eurobahn5 No one interested so I think... 25-11-2016, 05:24 AM
Stevo36 Hi - can anyone tell me an... 13-12-2016, 02:34 PM
Stevo36 Don't worry - got it :) 13-12-2016, 08:44 PM
eurobahn5 Yes you are right Elmura, my... 14-12-2016, 05:51 AM
  1. #23
    Mar 2015
    NSW
    Hi guys,
    Been a while since I updated this thread. I'm still using my "Elmura Cold Air Ram Mod" but now on my CC. The buyer of the R36 was keen to keep it on so I had to make a new one for the CC.
    For the CC, other improvements included cutting out the "comb" plastic filter that sits just behind the grille. This required unscrewing the cover that sits between the radiator and grille and removing this long plastic piece (see pic). I then cut off the vertical pieces of plastic "comb" filter.
    The idea behind this is to minimise obstruction (and thus pressure loss) for a superior RAM effect at speed. I also sealed up the gaps that adjoin the back of the grille with the intake scoop using strong tape that has held up thus far for almost 1.5 years.
    There's a K&N panel filter in the air box that gets cleaned every 20,000kms
    I siliconed sealed holes at the bottom the airbox to prevent hot air being pulled through.
    I applied fibreglass heat wrap to barrier the airbox from the oil cooler & insulated the oil cooler pipes to reduce heat transfer to the airbox. Further, I heat wrapped the exhaust in the engine bay (a major task that I don't recommend) to minimise heating of the intake manifold. I also fitted a reflective blanket over the intake manifold portion sitting behind the radiator as I found this to be a massive source of heat.
    #xR360As for the Forge intake, not only is it quite pricey, it's not designed to fit the CC or R36 engine bay. Also, the air box is quite small so I calculated that it would not flow as well as an optimised factory system.
    However, I have started prototyping a similar version designed to fit the CC & R36 with larger ducts, straighter air flow, a much larger air box and very large pod filter. Early experiments with unsealed approach (sucking engine bay air) had performance loss in most street scenarios - but an improved highway speed performance. The problem is getting the air scoop above the radiator to connect with the rest of the system.
    I had bell mouths fitted for smooth air transition and heatshield wrap around the "box". I tried aluminium piping & silicone. I haven't had time to complete this design though as I've been designing and owner building a house which takes up all of my time.
    Off thread topic - I also ditched the centre "suitcase" muffler and fitted a customised exhaust bypass valve (2nd version of this experiment). With this open and at RPM >2500, all sonic hell breaks loose and it sounds wicked. I've been told it sounds like a V8 Supercar, a Lamborghini, and "insane". At low RPM it's way too loud & droney so I keep it closed except when I'm rolling up to lights. I wanted to automate it but it's a hassle so I keep the little remote at hand.
    PS - In case your thinking I've completely lost it, I do have a Mechanical Engineering & Electronics Engineering background.
    Attached Thumbnails Attached Thumbnails Custom R36 Cold Air RAM intake - Almost alt=
