They need to be wired in, and then coded.
That is providing the door control modules have the capability.
Hi all,
I noticed that in the Carsales specs when I was searching for my car, it was listed as having "courtesy door lamps - front" and rear?
I've had a look at mine and I only have a cruddy plastic reflector on each door, well, 3 of them anyway as it seems the rear passenger side one is gone...
I originally thought the fuse was blown because no red lights came on when the doors are open (only puddles) and am a bit disappointed that even the wife's Cooper S has them, but my premium sports wagon does not.
I bought some speccy third party lamps from Aliexpress with the VW logo on them but it seems there is nothing to connect these to, wiring wise?
Does anyone else have factory courtesy door lamps in their R36 or is this just a Carsales Wikipedia mistake???
Any ideas as to whether the new lamps (which should fit the holes) will have anything in the door to actually connect to ?
Thanks
Chris
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I think when it is referring to courtesy lamps it means the puddle lights in the side mirrors.
There are no door lights. As Umai said you need to wire them up yourself and code the door controllers.
Bugger. That means I will need to know your preferred beer so I can impose on you to code them for me? When they arrive of course. I also wanted to ask now that I think of it, is there a code to change the red MPH speedo on the odometer to read KPH or is that a country dependent thing? Using the 0.0 button like the book says only turns the MPH off and not over to KPH. (Not that it matters too much anyway because the speedo is disgustingly over the real speed by about 10ks anyway)
You'll need to know which pins to connect them to also.
If you can't find them online let me know I'll see if I can find the wiring diagram.
Big Speedo shouldn't show mph unless you have it set in the MFD to alternate speed or whatever it's called in the settings
Ok that's weird. I've never owned a red MFD so unfortunately I'm not familiar enough with them but happy to take a look for you and check adaptation etc.
There must be a way to change it as there would be no way an au delivered car would be stuck with mph
Thanks Julian. When I receive them I will PM you to organize a catch up and a diagnosis session. Cheers
So visited Mr Kamold today for some magic VCDS programming and now I have (well one anyway, until I install the other three) a working door courtesy lamp with bonus VW logo/projection puddle. Looks pretty cool if you ask me
Thanks Kamold!
Link to AliExpress
Buy Products Online from China Wholesalers at Aliexpress.com for anyone interested in this
