Hi Snerlo, yep you have to code the lights in VCDS, Kamold was kind enough to do it for me. I have put both rear doors in, but the kits for the front had the wrong size pins for the door plug, so I have to wait for some other ones I ordered to come in this week. Door panels are quite easy to get off with trim tools and two torc bits. Wire the rear door ones to pin 6+ and pin 18-. And the front wire 18+ and pin 19-. Here is the guide I used https://youtu.be/dbNYZVqKAms
