Results 1 to 10 of 11
Thread: Passat Bend Light Failure
    Sep 2005
    Maroubra Beach
    Anyone had this error before?
    Im guessing one of the cornering bulbs are out?
    To change it is it something you can do from behind the headlight like the parkers?
    Or is it like changing the Xenon bulb and you have to remove the bumper?
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
    Jun 2015
    Willy, Victoria
    No need to remove the bumper for the cornering lights. They are fairly easy to swap.
    Sent from my SM-G955F using Tapatalk
    Sep 2005
    Maroubra Beach
    Ok thanks
    Do you know what bulbs to use?
    Bend light is the AFS headlights, not the cornering bulbs.
    Do your headlamps still 'dance' at startup (swiveling motor calibration)?
    Sep 2005
    Maroubra Beach
    I changed the cornering light and seems problem is gone.
    Ill check to see if they still dance.
    Thanks for the help.
    I sit corrected
    Sep 2005
    Maroubra Beach
    I sit corrected
    All good mate.
    Ill check the dance now as im paranoid.
    They should call you the R36 guru
    Mar 2014
    Melbourne, Vic
    I had this issue in the CC, for some reason the message displayed is bend light for the cornering lamp and dipped beam for the low beams.... I also thought the worst when I initially saw bend light thinking there's a issue with the movement of the motors or something like that, but they both self tested fine with ignition on and both worked which lead me to the cornering bulb.
    Now that I think about it I think the error when you have an issue with the swivelling HIDs is 'AFS error'
    Sep 2005
    Maroubra Beach
    Correct heard you can fix the AFS error by disabling the test in the MFD option?
