I could write thousands of words on the saga of the experiences with my 3.2L V6. I was getting check engine lights, limp home mode and a DTC for camshaft/crankshaft timing correlation. (00022 Crankshaft Position - Camshaft Position, Correlation Bank 1 Sensor A) The dealer analysed everything and diagnosed stretched timing chains plus the tensioner over-extended. I’ve since found out this is a common problem. The chains were replaced along with the main tensioner, two sprockets, engine rear oil seal plus other gaskets and bolts. There was no damage to valves or pistons.
5 months later, I had similar issues. This was diagnosed as an inlet cam adjuster with excessive free play, possibly the full 52 degrees of adjustment. Both adjusters had tested fine when the timing chains were replaced but one had now failed. So I agreed to replace both at a cost of $1,100 each for the part alone. Labour hours was the killer. The camshaft adjuster solenoids (also called valves) were in good condition and cost $500 each, so I accepted their advice that there’s no reason to change them. Both these jobs cost together cost many thousands of dollars. Again there was no damage to valves or pistons. However the dealer made a decision that from then on they would always replace the cam adjusters whenever they did the timing chains.
A couple of months later I had the same camshaft/crankshaft correlation error again. They concluded that one of the new cam adjusters (inlet again I think) had failed after only 2 months. They stripped the engine again and replaced the inlet cam adjuster. Fortunately the cam adjusters had been replaced by a dealer and VW offer both a parts and labour warranty. So this third job was done at no cost to me. If I'd gone to an independent garage, VW would have covered the part cost only under warranty. This is about the only time I've had work done at a dealer and I'm glad I did!
Your R36 is a 2010. It's probably around this time that VW realised they had a problem with timing chains on the 3.6 and 3.2 V6 engines and changed to a more reliable chains with a different part numbers. It's possible that later R36s did not have this problem, but many of the early ones did. My repairs were done in early 2015 and all of the critical parts had new part numbers.
Are you still having issues with the car Gonads00? Maybe the seller knew this would be an expensive repair and was happy to quit the car you bought at a low price? If this job is going to cost you $5K+, you could possibly source a used engine from a wrecker for less.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
