Hi Guys, so could some one please tell me what is the oil level using VCDS for a B6 125KW Passat wagon (editBMR engine). Diesel engine. I am getting 29mm.
Cold it is about 3mm above max whilst after a drive (warm engine) I can read max and see arrow dry on dipstick but the small knob directly above it has oil. This has been repeat tested about 6-7 times with the same result.
Thanks
