Quote Originally Posted by MatC View Post
also i get what you mean with the auto closing feature - but i was more talking about the coding - i'm still a bit green - and i'm sure if i trawled long enough i would find my answer, is there a thread with the coding so that VCDS and OBD11 pro users can manually code these things?
I don’t know on the exact coding but on VCDS you need to check two different boxes to get it to work. Once enabled they you will get the option on your MFD to turn it on and off.
