You'll also need the wiring harness and the microphone and it's wiring which is located in the head liner.
You can get them from wreckers but unless you pull the harness out yourself you might end up needed to buy a harness or repair what you get.
You might be better off just buying a new kit there are forum sponsors on here who sell the complete kit with everything you need.
Then you still need to code the car to tell it about the new module which can be done with something like VCDS or OBD11.
