Results 1 to 10 of 11
Thread: Battery Replacement
    Sep 2017
    Question Battery Replacement
    Hi There
    Long time between posting.
    I have to replace the battery in my wagon (r36) but I can't figure out how to remove the battery thats in it. It seems to be well constrained in the left rear and there is no bolts to loosen. Can someone give me the way the battery is removed please
    Cheers Bruce
    Hers: 2017 Passat 206TSI R-Line Wagon - Harvard Blue Metallic
    His: 2000 AU Falcon XR8 - Ex-Police - Winter White
    His: 2010 10.5 Passat R36 - Biscay Blue
    Pacific Paradise QLD
    Probably got clips right at the bottom on each side with a screw holding each one tight.
    Sep 2017
    Thanks, didn't see the bolt when I looked first time, I'll get my son to help
    Jun 2015
    MELBOURNE
    Quote Originally Posted by racedirector View Post
    Did you find the clips? They are located in the bottom corner of the battery.
    However, anyone know what is the additional cable connected to the negative terminal? (where is red arrow is pointing to)
    Do I need to disconnect this cable before disconnecting the negative terminal?
    Battery Replacement-screenshot-2021-07-05-163531-jpg
    Erskineville, NSW
    Why not go to a professional battery shop and buy a battery with free installation. They'll use a jump battery and you won't get the disco lights on the dashboard.
    To Louiz
    Also put a more specific LOCATION in your SIG so people know where you are and can offer local help for you.
    No good saying go to Campbelltown if you are in Kununurra
    Quote Originally Posted by louiz View Post
    Thats something aftermarket that has been fitted to the car. Eg lightbar, fog lights, different radio etc.
    Just disconnect the main negative terminal off the battery and it will disconnect the aftermarket item as well.
    Jun 2015
    MELBOURNE
    Thank you Lucas_R. It would be the trailer light port?
    Jun 2015
    MELBOURNE
    To Louiz
    Sure, i am still green here but i will figure it out
    Go up to top of page . Click on settings go down left side to EDIT PROFILE and you can do it there
    Good to see you have reply with quote fixed LOL
