Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Battery charger for Stop Start battery
    Pacific Paradise QLD
    Because I dont use the Wagon often the battery is going a bit flat between uses. HAd car serviced today and Service manager suggested I use a trickle charger on it between uses.
    Is of course an AGM battery and I was thinking along the lines of a Cetek 5 or 7 amp charger.
    They are a good brand and I have used one when 4Wding
    Suggestions please but I wont be buying any $50 cheapy
    Ive got the 5amp (MXS5.0) CTEK charger - works great and is nice and compact.
    Dec 2006
    Kilsyth, VIC
    Ive got the 5amp CTEK charger - works great and is nice and compact.
    Same here, highly recommended
    CTEK will happily stay plugged in the whole time if you want or you can just charge it up once a month (or as needed).
    Jul 2013
    Hills District
    I use CETEK 7.0
    Quote Originally Posted by Passat R36 View Post
    I use CETEK 7.0
    Yeah had one of them when I had a Cruiser and a van with 4 700CCA batteries between them but dont need that much or that many $$$ to trickle charge the Passat I dont think
    Thanks any way. Will go for 5.0 at $118
    Will connect the rings and then can take it out when necessary
    Anyone tried the test and charge MSX 5.0 Is it worth the extra $50
    Aug 2012
    Perth WA
    If you mean the MXS 5.0, I have one and can recommended it. It has an AGM and recondition function. I hook it up to the Passat and all my other cars once a month to top them up and check on their condition.
    https://www.ctek.com/Archive/Product...S%205.0_EN.pdf
    [QUOTE=Amalgam;1192129]If you mean the MXS 5.0, I have one and can recommended it. It has an AGM and recondition function. I hook it up to the Passat and all my other cars once a month to top them up and check on their condition.
    https://www.ctek.com/Archive/Product...S%205.0_EN.pdf[/QUOTE Was referring to this one which has a couple of maybe useful functions and was wondering if it is worth the extra money. I decided it wasnt and bought the cheaper one
    FREE SHIP- CTEK Battery Charger MXS5.0 TEST & CHARGE - CTEK Products - Power Generation
    Thanks for info I ended up buying a MXS 7.0 from Autobarn for $159 sale price Does the job perfectly.
    The online outfit stuffed me around so I cancelled it
    Further to this thread I had a flat battery today (Left reading lights on) and rang VW for cost of replacement $471.49 and $77 to fit and calibrate car.
    Rang Battery World who were dearer and also told me I have the wrong Ctek charger.
    Said they make a specific charger for Stop Start batteries. Have emailed Ctek to check if thats correct as havent seen them offered for sale in AUS.
    Not having a good day LOL
