Results 1 to 10 of 14
Thread: Bang for buck front pads/rotors? 340mm? 312mm? What?
    Dec 2018
    Hi there,
    I'm reading a plethora of mixed messages in regard to what pads and rotors fit my car. One site will say one thing, another will say something else. I'm capable of changing them myself, but do you think I can work out exactly what to buy?
    I don't need top end performance.. I just want well priced and reliable.
    Cheers.
    Dec 2018
    I should stipulate that its a 2012 125 TDI Highline sedan.
    Why not just pop a wheel off and measure them? I very much doubt you have 340mm disks on a Passat as these are whats fitted to the Golf R and GTI Performance.
    Much more likely that you will have 312mm disks as this will be VW parts bin stock and is whats fitted to normal GTI Golf.
    I just bought some Bosch disks from Automotive Superstore last week - they should arrive today or tomorrow. Their info suggests your car has 312mm front disks.
    They have a sale on at the moment with Bosch, Brembo, DBA, Protex and TRW disks/pads. Their prices are good so if you need brakes you may as well buy them now.
    Brake Disc Rotors | Automotive Superstore
    Dec 2018
    That site just confuses me.. down the bottom it shows my vehicle as compatible, but at the top it says it's not. There are so many options that I can't make heads or tails of it.
    Quote Originally Posted by SirFaffer View Post
    Bosch BD997 Brake Disc Rotors Pair | Automotive Superstore
    Dec 2018
    Would these be the correct pads?
    Bendix DB1849 EURO+ Low Dust Brake Pad Set | Automotive Superstore
    Thank you
    Thank you
    Yes they should be the correct ones. I just cross checked on the Bendix website and they have this part number as a match for a 2012 VW Passat TDI: https://www.bendix.com.au/shape/db1849
    Dec 2018
    Thank you very much
    Thank you very much
    You're welcome.
