Results 1 to 3 of 3
Thread: B7 TDI Oil filter housing mount bolts tension?
    May 2017
    Happy new year everyone…
    I had a water leak on my B7’s oil filter housing and decided to repair the leak myself. After removing the assembly, I have found damaged gasket groove causing the gasket to dislodge and water to leak.
    If anyone who have access to technical manual, could you please advise me on what is the torque tension when it’s been re-attach?
    Filter housing is held by 4 screws to engine block. (M8 Spline bolts)
    Cheers Las
    Attached Thumbnails Attached Thumbnails B7 TDI Oil filter housing mount bolts tension?-mir_20200104_183758-jpg   B7 TDI Oil filter housing mount bolts tension?-mir_20200105_130828-jpg
    Pacific Paradise QLD
    Here you go Its page 169 to 171
    Engine Passat.pdf - Google Drive
    May 2017
    Thank you very much. appreciate your quick response.
