Here you go Its page 169 to 171
Engine Passat.pdf - Google Drive
Happy new year everyone…
I had a water leak on my B7’s oil filter housing and decided to repair the leak myself. After removing the assembly, I have found damaged gasket groove causing the gasket to dislodge and water to leak.
If anyone who have access to technical manual, could you please advise me on what is the torque tension when it’s been re-attach?
Filter housing is held by 4 screws to engine block. (M8 Spline bolts)
Cheers Las
