Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 62
Thread: B7 Retrofitting - MIG's Passat
  1. #41
    May 2007
    Love seeing these updates! Hats off to you!
  2. #42
    Jan 2020
    Sydney,NSW
    Nice work all round MIG, The Carbon build up is telling, think mine has a walnut treatment in its future. Thanks for posting Vid.
    R36 Wagon MY2010.5: Biscay Blue| Dynaudio and Nav| RVC| VW tow bar|
    Mod highlights:
    ECU and DSG Tune| 3AA CCM and 7N0 Gateway| 3D colour MFD| MIB2 retrofit and 7N0 RVC| Quad LED tail, brake and indicator rings| Zimmermann Sportbrake rotors, composite pads| TPMS High| 2Q0 Blind Spot and RCTA| B8 rearview mirror|
  3. #43
    Mornington Peninsula, VIC
    Service position time
    B7 Retrofitting - MIG's Passat-20230416_150025-jpg
    Did not need to buy a T10093 Bunnings M10 x 120mm bolt does the trick for $3, this allows you to pull the front carrier forward to have access to the engine without draining the coolant \ AC system.
    Custom 3D printed adaptor for the walnut blasting; here is the link if anyone else wants to print one.
    VW VR6 Walnut blasting adaptor BWS 3.6 by MIGINC - Thingiverse
    B7 Retrofitting - MIG's Passat-20230417_184030-jpg
    The dam injectors pulled out with the block when I removed the lower fuel rail; BTW erwin is incorrect; you do not need to remove the HPFP when doing this service; only a 17mm flare nut spanner is needed.
    So while I waited to have the injectors resealed, a 180A alternator was installed, and I found that my washer pump was leaking, so replaced that too.
    Before and after the cleaning.
    B7 Retrofitting - MIG's Passat-20230416_162827-jpg
    B7 Retrofitting - MIG's Passat-20230417_150301-jpg
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  4. #44
    Wow, I am amazed that this pump was still working; it must have leaked and flooded the poor motor.
    B7 Retrofitting - MIG's Passat-20230417_215828-jpg
  5. #45
    Nice one I have that to do soon when I can find the time.
    Have you logged timing pull before and after the clean?
    I'm hoping it will help with this as mine is pretty aggressively pulling timing (10 degrees) at the moment.
  6. #46
    brisbane
    Great thread mate, love the updates and photos. Nice work!
  7. #47
    Nah, I don't have a timing log, the main issue I was having was cold misfires under light throttle low RPM, eg the onramp onto the freeway.
    Idle seems much smoother, will see about fuel economy.
    I can check the timing out now, what measuring value would you like?
  8. #48
    You need to log RPM, ign angle retard per cylinder, air mass, throttle valve position, ignition angle.
    Ideally in 3rd or 4th under load to max RPM.
  9. #49
    About to start posting again, watch this space.
    Here is a teaser
    B7 Retrofitting - MIG's Passat-screenshot-2023-10-17-141416-png
    B7 Retrofitting - MIG's Passat-screenshot-2023-10-17-140322-png
  10. #50
    Quote Originally Posted by MIG View Post
    Here is a teaser
    OK, I’ll bite.
    What are you up to now?
