I LOVE this thread!!! OEM+
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
PCB is nearly at the end of the design phase.
Features!
- 3 CAN Bus interfaces, one capable of CAN FD, selectable termination resistors, filtering and EMC that should match the OEM gateway.
- 2 LIN Bus interfaces
- Selectable MCU, Teensy 4.1 or Rasberry Pi Pico
- TVS surge protection.
- VW OEM Gateway connector, pin compatible with the gateway (Not that I could write a replacement gateway software). This is designed to supplement the original gateway.
So, is it essentially a general purpose, programmable control unit? You could do (practically) anything with it?
Correct, it will be a platform to do many mods on, both LIN and CAN bus, future versions may even have high side switches( eg open exhaust valve while in sports DCC mode)
Hoping it can lead to some more MQB gear running in the PQ platform. But could be used for anything really, not even limited to VAG group cars.
Once I clean it up after prototyping I will open source the hardware.
Sent from my SM-N960F using Tapatalk
R36 Wagon MY2010.5: Biscay Blue| Dynaudio and Nav| RVC| VW tow bar|
Mod highlights: ECU and DSG Tune| 3AA CCM and 7N0 Gateway| 3D colour MFD| MIB2 retrofit and 7N0 RVC| Quad LED tail, brake and indicator rings| Zimmermann Sportbrake rotors, composite pads| TPMS High| 2Q0 Blind Spot and RCTA| B8 rearview mirror|
No posts in a while; let's catch up with the new year. Happy new year VW fans!
1. Currently testing the rear climate control out of the VW Magotan (Chinese B7 that had a longer production run); if I can get the setup working, new trim with be needed for the armrest to complete it; this also adds the ability for rear heated seats.
2. Passenger side mirror has been swapped to a euro driver's side mirror; this adds dimming and an aspherical blind spot edge.
3. CAN reserve engineering is coming along; I now have a bench setup with an MQB BCM and ambient lighting to test with.
4. New BCM is in; rain closing now works (3AA 937 087 R).
5. Wheel logo caps are here, fit but a bit too loose for my liking; a shim needs to added to the old rims to keep it in place.
To come still,
Possible DQ500 swap, still in the research phase.
Seats out of a CC to add heated rear seats and maybe front air-conditioned seats?
Custom CAN gateway for more MQB goodies.
Rear climate control and heated seats are in, also installed the 230v invertor, with all this stuff added will probably need the 180A alternator next
In other news, I've completed the valve cover gasket replacement and PCV valve upgrade. While I had everything open, I took the opportunity to inspect the intake valves. Now I'm in the process of gathering the necessary equipment for a thorough walnut blasting
Video of the carbon buildup 2023 02 06 11 49 23 - YouTube
Still got plenty more to do![]()
