Results 1 to 10 of 13
Thread: b7 questions
    May 2016
    wallsend nsw
    b7 questions
    I have a 010 b7 I think, its a wagon the 1st problem is its using a ltr of oil every 1,500 ks is this normal.
    The second one, is that some times it just stops for a moment than it starts again. The car yard says their is nothing wrong with it. Do you think it needs a gearbox oil change, or just a service
    The 3rd one is can I use Penrite hpr 5 5w 40 extra 10 in it. Or is it to thick, I have 145,000+ on it
    Thanks in advance
    Pacific Paradise QLD
    Is it a diesel or a petrol and is it a Bluemotion ( stop start model) Not a lot of info there to go on.
    My 2011 TDI doesnt use any oil between yearly services
    May 2016
    wallsend nsw
    Sorry, its a 1.8 turbo petrol no its not a stop/start mod.
    May 2016
    wallsend nsw
    It turns out its a low fuel pressure problem, looks like I need a new fuel pump. Are there any good after market ones out there ????
    Quote Originally Posted by James b View Post
    There's plenty on ebay that will work.
    Look the number up on here Audi Teile Katalog (Pats Catalog) and google it
    Jun 2015
    South Eastern NSW
    Penrite HPR 5w-40 should be fine. The spec you need to meet is VW502/505. The HPR5w-40 does meet it. If you are still burning oil Nulon will have a product which is cheaper.
    08 Golf GT TDI
    11 (MY12) Passat TDI Wagon
    Personally I would stick to VW APPROVED oils. Like Penrite and Castrol Edge being the more common ones. Very few Nulon are actually approved. The exception is 5w-30 which recently gained approval.
    The rest say "Suitable For" which is vastly different to "Approved for"
    May not matter at your cars age and km's but for anything close to warranty it wouldnt pay to ask VW for anything if not using correct oils.
    Jun 2015
    South Eastern NSW
    After reading this thread I don't think a VW warranty in Australia is worth jack: Dreaded Cylinder 4 Misfire I think "vastly different" is probably overstating it Hillbilly - VW Approved just means they were prepared to pay VW the affiliation fee (some of which VW may have used to test the product - but they may have just read the indepedent test report) and sign up to whatever the commercial terms are to be on that list.
    08 Golf GT TDI
    Quote Originally Posted by ozrcboy View Post
    Your car, your money, but I know what I choose to use as both of mine have done under 30,000km
    Dec 2008
    Sydney/Canberra
    That warranty will be worth a whole lot more to you when they tear it up over using the wrong engine oil.
