Results 1 to 7 of 7
Thread: B7 Passat services
    May 2017
    B7 Passat services
    So I am looking around for a 2011 onwards passat for the wife.
    What are peoples thoughts on regular services documented, however
    the last one was at 53k, almost 2 years ago. The 60k with gearbox service hasn't been done
    and the car now sits at around 67k. Owner has said will get the service done when I pointed
    this out. BTW this is the 6 speed dsg.
    Aug 2012
    Perth WA
    Hi,
    I would be reluctant to purchase any car with such a hole in the service history, unless is is at a giveaway price that might cover any failures. IMO a well maintained higher mileage car is better than a poorly low milage car.
    There are plenty of Passat for sale at very reasonable prices. I would look elsewhere.
    May 2007
    Passat service schedule; 12mths / 15,000km (or whichever comes first).
    So theoretically it should now have had 5 services and should be at its 5yr / 75,000km service.
    When you say regular services documented, it sort of indicates to me it has only had its 1, 2 & 3yr services completed.
    And most likely not based on mths or Kms...
    When you say 6spd DSG, are you referring to TDI or V6 FSI? (The TSI was a 7spd DSG)
    Jan 2015
    Melb
    I wouldn't knock it back just because one service is overdue by time. Is the earlier history ok? How many stamps? I guess the dsg etc is a bit overdue but not a lot. Brake fluid will be due too.
    Dec 2008
    Sydney/Canberra
    If it were me buying it, I wouldn't stress too much.
    It's more important to know what's actually been done in the previous services. Eg, the air filter done at the 45K/3yr service, brake fluid every two years, that sort of thing.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2017
    Quote Originally Posted by ope126 View Post
    Sorry, looking at v6, 2011.
    Thanks all for response
    Had a drive and closer look at history.
    Was a bit iffy. The 1st service was dealer stamped, 2nd service had no stamp, the 3rd service was done (54k) at Kmart auto
    and now at 67k (the 60k due I suppose)
    From what I can determine the car was a demo and had a service when sold (5k or so)
    One of the service intervals was out to almost 20k as well which is why the kms are
    all out. Owner was a bit vague about it all.
    Drove fine however cosmetically needs a little help
    I think if the car was was a little tidier and showed
    signs of being looked after a bit better could
    look past the history but gut feeling says no
    Dec 2008
    Sydney/Canberra
    Yeah, probably not worth the hassle.
    '01 Beetle 2.0
