Results 1 to 4 of 4
Thread: B7 passat door panel
    Dec 2015
    I hope someone has already been down the road of taking off the door panel on the B7 Passat.
    i have googled, youtubed, and searched the forms, and all that comes up are instructions for the NA Passat, which might as well be a different car.
    where are all the bolts to take off the door panels on the B7 passat?
    I have found the bottom two twisty bolts, taken off the handle part and uncovered a torx screw there, and managed to only take off half the silver trim.
    has any anyone got any links, or instructions, would be much appreciated?
    Pacific Paradise QLD
    I have taken a rear door panel off and you need a set of body panel tools as they slide into plugs that need to be pulled apart to release them There is also one right in the centre of the rear door that i couldnt reach and I eventually use a chisel bit off a Kango and pushed it in and twisted it and it popped the plug There are screws bottom centre as I remember but its two years since I did it also some trim to come off at the inner handle and armrest Once free it just lifts up like slide it up the window.
    Like these 6pc CAR Body Dash Door Trim Panel Wedge Clip Remover Removal PRY Tool P373124 | eBay
    The clips are sort of similar to these and need to be popped to look as these are shown before the skin will come off
    Audi VW Body Trim Panel Retainer Clips C526 | eBay
    I have a PDF with instructions if you PM me with your email address I will send it to you but for $30 you can dowload the manual for the whole car from ERWIN
    Oct 2015
    Brisbane QLD
    Where can I download this manual from Erwin ?
    Quote Originally Posted by daniel8810 View Post
    Well by using everyones friend Google I came up with this
    https://erwin.volkswagen.de/erwin/sh...6B.ASTPERWEU01
    Get an account pay about $30 Euros and you get 24 hours to download all you can eat
    Thats what I had to do to get the stuff for my two.
