I have taken a rear door panel off and you need a set of body panel tools as they slide into plugs that need to be pulled apart to release them There is also one right in the centre of the rear door that i couldnt reach and I eventually use a chisel bit off a Kango and pushed it in and twisted it and it popped the plug There are screws bottom centre as I remember but its two years since I did it also some trim to come off at the inner handle and armrest Once free it just lifts up like slide it up the window.
Like these 6pc CAR Body Dash Door Trim Panel Wedge Clip Remover Removal PRY Tool P373124 | eBay
The clips are sort of similar to these and need to be popped to look as these are shown before the skin will come off
Audi VW Body Trim Panel Retainer Clips C526 | eBay
I have a PDF with instructions if you PM me with your email address I will send it to you but for $30 you can dowload the manual for the whole car from ERWIN
