The bumper needs to come off; check out the really early pictures in my image library there are bolts on the underside of the lights.
Passat Upgrades - Google Photos
2013 v6 wagon.
Trying to remove the headlights to retrofit led globes (yes, I know)
I can get the leds in there, but the rear caps won't go on so I need to remove the headlights to fit them up properly
So far I've got the grille off, and two of the adjustment threads off (pic 1 and 4) and the lights are loose, but it feels like there is a bolt or something at the bottom stopping it from sliding out.
Do I need to drop the bumper away?is that just the 2 bolts on the wheel arch and the 4 on the radiator support?
Sent from my SM-T835 using Tapatalk
2013 MY13.5 Passat V6 Highline Wagon. Watch this space
GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
I was hoping that wasn't the case. Thanks again Mig
Done. All in all, the extra 10 bolts and 20 minutes made it so much easier.
I fitted up lightforce h7 low beam globes, and they went in pretty easy. As they use a separate (canbus compatible) driver module, I chose to remove the lights so I could mod the rear caps and mount the driver module properly. I couldnhave gotten the globes in, but with the amount of stuffing around to get the flexible heatsinks in and the drivers it was the right call to remove them
I probably should have taken pics, and can if needed.
