Hi mate, these are the instructions I got when I did mine :
The larger connector block that has 20 pins, need to swap pins 16 and 20. They are different gauge though so you have to cut and join
I also had to do the flap calibration, then do the compressor run in with VCDS.
Hope this helps.
