Results 1 to 4 of 4
Thread: B7 3-dial Climatronic Retrofit into MY10 R36 - Wiring?
    Sep 2010
    Do any wires need to be swapped over on the harness for proper functionality?
    I am coming from the old 'MK5' style climatronics unit.
    '18 MY18.5 MK3.5 Octavia vRS245
    Previous - 2015 MY16 MK7 R, 2010 MY10 R36 DSG, 2010 MK6 Golf GTI DSG // APR Stage 2, 2006 MK5 Jetta TFSI DSG // Revo Stage 2, 2006 MK5 Golf GTI Manual
    Hi mate, these are the instructions I got when I did mine :
    The larger connector block that has 20 pins, need to swap pins 16 and 20. They are different gauge though so you have to cut and join
    I also had to do the flap calibration, then do the compressor run in with VCDS.
    Hope this helps.
    Sep 2010
    Thanks!
    Did you have to cut off parts of the faceplate to make it sit flush?
    The back protrudes out at the top compared with my old B6 faceplate.
    Mine is out of a 2014 Passat. I wonder if a faceplate out of a CC is a better match for the B6.
    Yes I had to trim the faceplate to fit, was a pretty easy job though.
