There should be a campaign number printed on the recall sticker which should tell you what recall work was done. I think you'll find it was for the incorrect DSG fluid recall - one of these two:
Volkswagen Group Australia Pty Ltd—Polo, Golf, Golf Wagon, Golf Cabriolet, Beetle, Jetta, Passat, and Caddy Vehicles <- Affected models built between 2008 and 2011
Volkswagen Group Australia Pty Ltd—Polo, Golf, Golf Wagon, Golf Cabriolet, Jetta, Passat, and Caddy Vehicles <- this one affected MY2013 vehicles, which yours might be
To my knowledge, there was no recall for the lean burn issue in the 118TSI (there may have been a service campaign, I'm not sure) - even if there was, it was for the 1.4l twin-charged engine fitted to Golfs, not the 1.8l turbo fitted to your Passat.
The 7-speed DSG shudder may have been a premature clutch pack wear issue - if a reset has solved your issue, hopefully it's a permanent fix. If not, as I understand it, the latest revision of the clutch packs resolves the issue.
Regarding the oil consumption issue - your car is likely to be less than 12 months out of new car warranty (if you don't have an extended warranty) - it might be worth approaching a VW dealership for a goodwill repair of the excess oil consumption. You've got nothing to lose. IIRC, VW consider 1l/1000km to be acceptable - but you are well above this at 1.5l/1000km, so between VW wanting to rebuild customer confidence and you nudging them with the ACL, they might just say yes to a goodwill repair.
