245/35 will put speedo slightly further out
So the OEM fitment is 234/40 on the standard 18 inch rim.
Anyone know if we can run 245/35 or 245/40 without running into any tyre/guard contact issues?
Noting what Hillbilly said, I'd add, for clearance probably all good, depending on the spec of your current suspension. Lower profile and wider will change the ride characteristics, you may also notice some extra tyre noise.
Have a look at one of these calculators, plenty around on-line, also plenty written in the B6 and B7 forum on tyre and rim upgrades. I'd also check the new tyre rating meets or exceeds the tyre placard on your car.
Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
R36 Wagon MY2010.5: Biscay Blue| Dynaudio and Nav| RVC| VW tow bar|
Mod highlights: ECU and DSG Tune| 3AA CCM and 7N0 Gateway| 3D colour MFD| MIB2 retrofit and 7N0 RVC| Quad LED tail, brake and indicator rings| Zimmermann Sportbrake rotors, composite pads| TPMS High| 2Q0 Blind Spot and RCTA| B8 rearview mirror|
