Results 1 to 10 of 11
Thread: B6 wagon missing some led's in tail light
    Jul 2010
    Elanora Heights, Sydney
    Hey guys,
    My wifes B6 has some non-emitting led's in her left tail light. Its the outer ring (not the brake light) and about 1/4 of the ring does not illuminate at all.
    What could the issue be? LED's shouldn't "blow" so is this only fixed with a new outer light housing? I had no love searching ECS for parts or passatworld for info..
    Christian
    Mar 2010
    Same for me with the right unit on my R36. Also a couple in the indicator not working. In for a service in a week or so, keep you posted.
    MY10 Silver R36 Wagon
    VW Classifieds Username - VWC-adrock
    Jul 2010
    Quote Originally Posted by adrock View Post
    I had a close look tonight and it seems that part of the tail light has corroded. One on the indicator doesnt work either, its a bit strange, looks like the drivers side is starting to corrode as well.
    Dec 2008
    Sydney/Canberra
    Has it got a towbar? Sounds crazy, but they have to removed to get the bumper off to fit the towbar. Sometimes installers can be a little rough with them, cracking the hounsings, causing the LEDs to eventually fail.
    Unless you're a whizz with electronics, the only way to rectify the problem is to replace the tail light.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2010
    Nope, no towbar for me.
    Jul 2010
    Nope, me neither.
    ECS has replacements for $150 - might just have to do something like that.
    Dec 2007
    ivanhoe vic
    [hey guys I have the same issue on my rhs tail light 07 wagon quarter of the brake light and one of the indicator lights on the outer ring, still under extended warranty and next service not far away so will see what they say, left one is fine.
    B6 Passat Wagon No KESSY
    Mar 2008
    North Lake WA
    Quote Originally Posted by OilBurna View Post
    Keep us posted, I see a number of B6's with this problem around Perth.
    WestOiler125
    MY13 Passat Alltrack
    125kW 2.0L TDi DSG
    Dec 2015
    Clive, New Zealand
    Failing LED tail light
    Quote Originally Posted by WestOiler125 View Post
    I know it has been a while since the initial post but I had the same problem just now and wanted to share the fix.
    I used a hack saw to remove the back of the housing ( if you have a Dremel, even better ) then had access to the LED. 2 broken solder joints were easily found, resoldered. that fixed it. I used Sikaflex MS to glue the housing back together.
    B6 wagon missing some led's in tail light-cut-tail-light-jpg B6 wagon missing some led's in tail light-taillight1-jpg B6 wagon missing some led's in tail light-taillight2-jpg
    Jul 2010
    I don't think mine is the same problem. When looking into the light from outside you can see some corrosion around the led's. I'll post pics soon.
    Sent from my SM-G920I using Tapatalk
