Before MY10, they're not pre-wired, so you need to buy the full wiring kit and wire it into the fuse boxes in the dash. A used wiring kit will very likely get damaged beyond being usable, as you need to know how to de-couple the locking mechanisms inside the fuse boxes, to de-pin the wires, which require a special terminal tool. You also need to pretty much gut the interior of both cars to swap it over.
Looks like this:
![B6 trailer wiring module-2k0055204b-jpg](https://www.vwwatercooled.com.au/forums/attachments/f234/34153d1528882762t-b6-trailer-wiring-module-2k0055204b-jpg?s=b5aa801bd31932935d6f3c2d21d9de51)
If you've never done one before, it will take you forever to fit, and you'll break every plastic part you touch.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
