B6 R36 Passat - Dynaudio Retrofit
Here are some details for anyone who is interested in retro-fitting a Dynaudio system into an R36 Passat.
I ordered a 10-speakers + amp Dynaudio sytem from a wrecked 2010 R36 Wagon. The plan is to retro-fit these into my 2008 R36 Sedan, replacing the stock 10-speaker, 250W system.
Here's a photo of the components that arrived this morning:
Part numbers are:
Amplifier - 3C0 035 346 J - Lear brand, 10-channel, 600W
Front Tweeters - 3C0 035 411 D (81310) - 6 Ω, approx ?2 inch, ??W
Front Bass+Mid - 3C0 035 454 B (85771/T85770) - 8Ω (both wired to 4 pin plug), Bass: approx 7 inch/??W, Mid: approx 3.25 inch/??W
Rear Tweeters - 3C0 035 411 E (81180) - 4Ω, approx ?1.5 inch, ??W
Rear Bass - 3C0 035 453 B (84899) - 8Ω, approx 5.75 inch, ??W
Note: I measured the speakers baskets (not cones), left/right part#'s are identical
(will post more specs as they become available) - if anyone can help with details like speaker ratings (??W), crossover frequencies (X-Y Hz) etc, that would be greatly appreciated (thanks).
I'll post some photos of individual components later and details of how the install goes. AFAIK - the amp and speakers are plug and play replacements for the standard system using existing wiring (we'll see if this assumption is correct soon).
BTW - I was investigating if it was possible to use the speakers from an Eos system (also 10 speakers from the "Confidence" package) when these became available. My thinking is that if they're the same size/impedance/power rating, then they should at least be compatible - my assumption is also that the Passat-specific 'tuning' would be done digitally by the amp (and not by changing the characteristics of the speakers somehow).
