Right - it was a 'K' version (Australian car).
It took me a couple of months to find the parts. I had actually emailed the wreckers (via eBay) around a month ago, but they didn't want to split the door trims up at that time - I asked again around a week ago and they had changed their mind
ebay.de seem to have a lot more Dynaudio listings - regardless of the site, make sure to select 'Worldwide' (or 'Weltweit' ) in your search. If German is a difficult language, a lot of the German listing show up on ebay.co.uk (once again, select 'Worldwide').
I was also looking into using speakers from an Eos (also 10-speaker, 600W 'Confidence' system) - more abundant and cheaper. I'm still researching this and it seems at this stage that the 7" bass drivers are the same (both have 'T85770' on them, which I presume to be the Dynaudio part#). The 5.75" rear bass drivers also appear to be the same, though I'm still trying to find a clear photo of the labels to confirm this. The tweeters have different numbers but appear to be the same size/impedance - may just be the different frames that justify a separate number. Either way, you would need to do some surgery to get the Eos speakers into the Passat frames, but it does provide opportunity to build better (custom) baffles etc.
The 'Confidence' system is shared across Eos, Passat, Passat CC, Touareg and Multivan models, though the VW part numbers and housings definitely differ. The Passat system at least is supposed to be specifically tuned for that model, which I would expect to be done in the DSP (where tuning is usually done) and not the speakers (?? somehow).
Also, JKU.com.au (Sunshine Coast Qld) can source the system and fit it for you. The price I was quoted for the parts was higher, yet quite comparable to the price I ended up paying. I was also told it would arrive within 10-15 days.
