![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Timlin
Does one have to remove the passengers seat to fit the amp?
The amp install was the easiest part and only took ~15 mins (I'm not that mechanical either).
I didn't have to remove the seat. Just slide it all the way back and up (lift the front of the bottom cushion - ie. tilt it back).
![B6 R36 Passat - Dynaudio Retrofit-20140503_102928-jpg](https://www.vwwatercooled.com.au/forums/attachments/f234/9260d1399199289t-b6-r36-passat-dynaudio-retrofit-20140503_102928-jpg?s=ab36f43bc4a631ec49005a66bc5a2b53)
Remove the radio fuse - it was f19 on my R36 (back-right corner of the engine bay)
![B6 R36 Passat - Dynaudio Retrofit-20140503_102701-jpg](https://www.vwwatercooled.com.au/forums/attachments/f234/9261d1399196894t-b6-r36-passat-dynaudio-retrofit-20140503_102701-jpg?s=ab36f43bc4a631ec49005a66bc5a2b53)
Then you remove the amp cover and unscrew the two bolts. Each have a 10mm socket and Torx screw option - my T30 bit seemed loose, so used the socket. There are only two bolts at the front, I originally thought there were four (two front + two back) based on the amp.
You can then slide the amp out and with a little gentle manipulation access the plugs. There are clips on the top and bottom of each plug that need to be lifted while gently levering the plug out - a little fiddly, but possible.
![B6 R36 Passat - Dynaudio Retrofit-20140503_101930-jpg](https://www.vwwatercooled.com.au/forums/attachments/f234/9262d1399197083t-b6-r36-passat-dynaudio-retrofit-20140503_101930-jpg?s=ab36f43bc4a631ec49005a66bc5a2b53)
Once you remove the amp, there will probably be a bunch of fossilized french fries, dust kitties and hopefully money under there. I was lucky and found a dollar to go towards the subwoofer fund =) ..
![B6 R36 Passat - Dynaudio Retrofit-20140503_102255-jpg](https://www.vwwatercooled.com.au/forums/attachments/f234/9263d1399197174t-b6-r36-passat-dynaudio-retrofit-20140503_102255-jpg?s=ab36f43bc4a631ec49005a66bc5a2b53)
The Dynaudio plugs are facing the opposite direction. Turn the amp upside down, plug it in, gently turn it back over (be very careful while twisting the wiring around) and manipulate it into place. Slide it back in, do up the bolts and replace the plastic cover.
![B6 R36 Passat - Dynaudio Retrofit-20140503_102632-jpg](https://www.vwwatercooled.com.au/forums/attachments/f234/9264d1399197396t-b6-r36-passat-dynaudio-retrofit-20140503_102632-jpg?s=ab36f43bc4a631ec49005a66bc5a2b53)
Finally, replace the fuse and turn on your head unit to ensure it all works ok and you get sound. Just be careful not to turn it up past ~60% or you may eject the Blaupunkt cones out of their baskets - my bass starting making 'blarp!' noises at that volume.
Timlin
Is there much real estate under there? Do you reckon I'd be able to fit the TV tuner under there as well?
TV Tuner? Sounds interesting =) .. another mod for the TODO list.
There should be enough room behind the amp, but you may need to remove the seat for that one. Try sliding it all the way forward/up and see what the access is like.
Timlin
I've seen the Dynaudio stickers/labels on eBay somewhere I think... bugger changing the grills!
Really? Sounds good enough. Do you know where I can find these (I'll start searching)?
