I bet that was a satisfying result. BTW check the time stamp on your edit 03:12 PM
So my headlights got so bad it was dangerous to drive at night.
I'd already replaced the stock D1S with new genuine Philips Xtreme Vision so I knew it wasn't the bulbs.
After some research I discovered that the Valeo projectors inside the headlights are known for burning out at the back, causing light output to drop.
I bought a set of lightly damaged headlights from a wreck and some plastic welding tools to repair the broken tabs.
Bought a set of Aharon Optimus NT projectors for Right Hand Drive (also known as Left Hand Traffic) from Retrofit lab:
Aharon Optimus NT - Bi-xenon projectors Hella design
Cut the headlights open with a dremel in order to access the projector assemblies within:
Needed new brackets to mount the new projectors as they are slightly fatter and deeper:
Sealed up the headlights with plastic weld staples and Sikaflex 227:
Original low beam:
Upgraded low beam:
Cutoff:
Original High beam:
Upgraded high beam:
Inner shrouds:
TAOCHIS Car Styling Shrouds Mask for 3.0 inch HELLA 3R G5 Koito Q5 Bi Xenon Projector Lens Retrofit Head Light Volkswagen Tiguan on AliExpress
Brackets:
TAOCHIS Adapter frame Head light for VW Volkswagen Magotan Adaptive Frontlighting System AFS Hella 3R G5 Projector lens-in Car Light Accessories from Automobiles & Motorcycles on AliExpress
Yeah super satisfied with the result. I really appreciate being able to see where I'm going in the dark...
Not sure I understand the edit comment?
Well done. Your ability to do upgrades never ceases to amaze me. I want to be around when you eventually sell your car!
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
Never selling it. Just upgrading.
Actually got it out in the dark tonight and it's sooooo much better.
Looking forward to a proper night drive in the country now.
Shutters open for some high beaming
That’s a fantastic upgrade!
Do the new lights come with the shutter motor? Mine is faulty on one light.
nice work - as always
that is a huge difference there.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
