Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: B6 Projector Upgrade
    So my headlights got so bad it was dangerous to drive at night.
    I'd already replaced the stock D1S with new genuine Philips Xtreme Vision so I knew it wasn't the bulbs.
    After some research I discovered that the Valeo projectors inside the headlights are known for burning out at the back, causing light output to drop.
    I bought a set of lightly damaged headlights from a wreck and some plastic welding tools to repair the broken tabs.
    B6 Projector Upgrade-headlight-repair-tab-jpg
    Bought a set of Aharon Optimus NT projectors for Right Hand Drive (also known as Left Hand Traffic) from Retrofit lab:
    Aharon Optimus NT - Bi-xenon projectors Hella design
    B6 Projector Upgrade-projectors-jpg
    Cut the headlights open with a dremel in order to access the projector assemblies within:
    B6 Projector Upgrade-headlight-open-1-jpg
    Needed new brackets to mount the new projectors as they are slightly fatter and deeper:
    B6 Projector Upgrade-brackets-jpg
    Sealed up the headlights with plastic weld staples and Sikaflex 227:
    B6 Projector Upgrade-headlight-sealed-jpg
    Original low beam:
    B6 Projector Upgrade-original-low-jpg
    Upgraded low beam:
    B6 Projector Upgrade-upgraded-low-jpg
    Cutoff:
    B6 Projector Upgrade-cutoff-low-jpg
    Original High beam:
    B6 Projector Upgrade-original-high-jpg
    Upgraded high beam:
    B6 Projector Upgrade-upgraded-high-jpg
    B6 Projector Upgrade-high-beam-jpg
    Inner shrouds:
    TAOCHIS Car Styling Shrouds Mask for 3.0 inch HELLA 3R G5 Koito Q5 Bi Xenon Projector Lens Retrofit Head Light Volkswagen Tiguan on AliExpress
    Brackets:
    TAOCHIS Adapter frame Head light for VW Volkswagen Magotan Adaptive Frontlighting System AFS Hella 3R G5 Projector lens-in Car Light Accessories from Automobiles & Motorcycles on AliExpress
    Dec 2010
    Helensburgh
    I bet that was a satisfying result. BTW check the time stamp on your edit 03:12 PM
    Yeah super satisfied with the result. I really appreciate being able to see where I'm going in the dark...
    Not sure I understand the edit comment?
    Dec 2014
    Well done. Your ability to do upgrades never ceases to amaze me. I want to be around when you eventually sell your car!
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Never selling it. Just upgrading.
    Actually got it out in the dark tonight and it's sooooo much better.
    Looking forward to a proper night drive in the country now.
    A little darker
    B6 Projector Upgrade-20191123_203525-jpg
    Shutters open for some high beaming
    Attached Thumbnails Attached Thumbnails B6 Projector Upgrade-20191123_203530-jpg
    Jan 2015
    Melb
    That’s a fantastic upgrade!
    Do the new lights come with the shutter motor? Mine is faulty on one light.
    Quote Originally Posted by Passat my07 View Post
    Yes the projectors have the shutter motors in them.
    Jul 2010
    nice work - as always
    that is a huge difference there.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
