Hey Throbbinhood, you know a great question , it does take a while to boot, it's pretty much the same as any smartphone boot up time.
Yep, with the android unit in the reg, the reverse camera will override any source, maps, audio etc, so if you are in reverse it will show in the screen but only after boot up. It also has the guide lines, which Yu can turn on or off.
Noticed on the android unit it does have a DVR function to, so you can install a forward mount camera and record onto the unit via an SD card or what every , if Yu are into these forward mount cameras.
