Results 21 to 30 of 32
Thread: b j p's R36
  1. #21
    Nov 2010
    Camira
    Welcome to the R36 pack b j p. Would be keen to meet up with you and Snerlo, might even be able to wrangle Chris in too.
    Gruppe M intake is a bit to expensive for me to justify at the moment.
    LED upgrade makes all the difference. I put up a DIY thread if you haven't checked it out already.
    Have to get a photo of all our R36's in Brissy. More and more are falling into the right hands now.
    Rising Blue MY10 Passat R36
    BLACK '97 Mk3 GL 2.0L
    White '82 MK1 Cabrio 1.8L
    Vice-President - VWDCQ (VW Drivers Club of Queenland inc)
  2. #22
    Apr 2014
    Sounds good mate.
    Small update. Walked through Autobarn the other day and spotted VW tyre valve covers. No body steal them
    DRL's turned up as well, so will look to install them over the weekend. Hopefully the new numberplates are in by the end of the week as well. Considering removing the ridiculously large number plate holders and screw straight into the front bar. The plates are small enough that should anyone ever remove them for normal plates, they'd easily cover the holes.
  3. #23
    Nov 2010
    DRL install should be relatively easy mate. Just check out my thread and you should be all sweet. Gotta give my old girl a bath over the weekend and give her a vacuum. Hasn't been touched since before Chrissy. Been having reno's done at home so there's been no point, but it all finishes today!! Yippeee. Looking forward to seeing the R all clean again
  4. #24
    Apr 2014
    So, after the weekend:
    DRL's installed
    VW Umbrella "installed"
    Interior LEDs installed
    Numberplate LEDs installed
    Puddle LEDs installed
    Billet paddle shift extenders installed
    Prorack Whispbars low-profile roofracks installed
    Also dropped the car down to a recommended local trimmer who fixed up the bottom side bolsters on the seats and they're like new again.
    Only issue after all that is I have thrown an airbag fault warning after fitting the LEDs, reading says a VAG-COM/VCDS will fix.
    | 2008 R36 Wagon | Black | Dynaudio | Auto-Tailgate | RNS510 | RVC |
  5. #25
    Mar 2013
    Brisbane QLD
    Airbag light is most likely on due to the seat fitter...prob removed seat with ignition on to do his job...a blown fuse of any kind should not cause a airbag light fault.
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
  6. #26
    Apr 2014
    I'll send him the invoice of you fixing it Pete
  7. #27
    Mar 2013
    Brisbane QLD
    tripple my price then!
  8. #28
    Jan 2015
    Hi BJP
    How much did that cost? they had to remove the bottom side bolsters i assume? then re-pack the filling?
    Quote Originally Posted by b j p View Post
    DRL's installed
  9. #29
    Apr 2014
    $150 per seat. Yep. Seats out. Remove electrics, remove covers, remove "foam", replace "foam", shape "foam", reinstall cover, reinstall seat. He reckons that he might be able to do it cheaper now they've done it once. The place I used in QLD does a lot of hot-rod interiors etc so they're car enthusiasts as well. Results are great.
  10. #30
    Mar 2011
    Lidcombe, NSW
    Hey BJP,
    I want to do my seats but am in Sydney, NSW.
    Do you mind asking the guys who did yours if they have anyone to recommend in Sydney or amI able to get the contact details off you?
    Bought my car off a big bloke and the side bolsters have NO foam.
