Results 21 to 30 of 31
Thread: Anyone fitted a Haldex performance controller?
  1. #21
    Unfortunately the Competition controller is only available for the Golf R. And yes it does provide greater engine braking by keeping the rear clutches engaged, though I have also heard these units can also cause the rear diffs, prop-shafts and transfer cases to break.
    Moral of the story is do your research.
    Jul 2014
    Quote Originally Posted by 3C4M Guy View Post
    It seems logical to me to always "retain rear driveline engagement under braking". Why wouldn't you want this? Surely this would deliver better engine braking.
    tigger73 as before has beaten me to it but to back him up, it increases wear on the driveline as it was not intended to be stressed this way and can cause failures, however this is irrelevant because he is completely correct that it is only available on the Golf R units. There is no technical reason why the R36 can't do it, it's just that nobody made a competition unit for them.
    I did a full lock turn today on a flat road doing a U turn in a side street and made a mental note of what maximumxposure said, there is absolutely no problems on my unit with this, I've currently got almost brand new Potenzas, but I used to have Eagle F1's on and it wasn't a problem at any stage through their life. I don't believe the problem being described is to do with the Haldex upgrade. Unless his unit is faulty but I'd say there is probably something else at play there.
    All of the information available in this thread and more is available on the HPA website by the way, including all sorts of info about engagement curves in the different modes, what is available and for what models, prices (Contact them though to get a best quote) and whatever else you want to know. Just dig around.
  3. #23
    Mar 2015
    Central Coast NSW
    Seems that perhaps it was just the particular carpark surface, I've had a similar issue in my old Liberty 3.0RB when the centre diff failed so i guess I immediately jumped to this conclusion. Testing last night on various road surfaces, left and right lock, forward and reverse and no issues to report thankfully.
    Appreciate you taking the time to check for me as well Jakey.
  4. #24
    Dec 2014
    Quote Originally Posted by maximumxposure View Post
    I installed the Haldex controller over the weekend, really simple install and obviously went straight to the race mode setting.
    Sounds like the install was a simple DIY maximumxposure. I believe you had access to a hoist. Would you attempt the job with the car just up on jack stands? Did you lose much Haldex oil switching over the controller? Also, how did you decide where to drill the hole through to the boot?
    No photos I suppose? (Sorry for all the questions!)
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
  5. #25
    Jul 2014
    I didn't do the install of mine myself, I had it done with a service. But I don't believe they drilled anything, the cables were passed through a grommet somewhere. My Haldex box (I guess maybe it's just for the controller so not everyone will have this maybe?) is cable tied next to my battery in the wagon.
  6. #26
    Mar 2015
    Central Coast NSW
    Yeah it was a simple installation process (about 15 minutes). Could definitely be completed on jack stands as you're only under the car for about 10 minutes to swap the controller unit and then run the cable. Oil loss was very very minimal, maybe 10ml at most. I mounted the Haldex remote box in the spare wheel well, drilled a 15mm diameter hole to the right of the spare wheel, passed the connector through a grommet and stuck the remote unit to the right of the spare wheel using the double sided tape that comes with the controller. Only downside is you can't hear the beep when changing between settings due to the thickness of the spare wheel cover etc, but as Tigger and Jakey have suggested, once you're in race mode you will probably not go back to Stock.
  7. #27
    Dec 2014
    I've received a reply from HPA that gives some further details. These apply ONLY to the Gen 2 performance controller - NOT the Gen 4.
    If the Gen 2 controller is installed without either the remote or the switch/cable, then it will default to SPORT mode, not RACE mode. The controller would be stuck in an inferior performance mode. The only way to change out of SPORT mode to RACE mode is to connect a switch or remote.
    However if you don't want to permanently install the switch/cable or the remote/receiver, then it's possible to raise the car, temporarily connect the switch to change to RACE mode, then remove the switch. Alternatively it's also possible to do what I read one person has done - permanently connect the switch and cable but leave the cable with switch coiled up in the spare wheel well. That way, the cable doesn't have to be run to the centre console.
  8. #28
    Mar 2015
    Central Coast NSW
    That's correct as per the instructions that I received with the unit.
  9. #29
    Apr 2009
    Northern Tasmania
    I've had a Gen 2 in my 2008 Skoda Octavia 4x4 wagon since Oct 2014. Cost about A$1500 (was discounted and I think the A$ was higher). It's the wireless version which is a doddle to install. Saves having another knob under/in the dash.
    Being my 'nice' car I'm a little hesitant to really hoon in it (though it sure is set up for it), so it is a little hard to pick the difference on bitumen, but boy howdy (anyone remember Motor Mouse & Autocat?) on dirt roads it is fun. I just wish I could try it on a safe, closed road that has nice easy shoulders for a safe runoff.
    If I'm just driving normal (not particularly windy) roads, particularly if for economy, I put it in Standard. If I'm on interesting roads or feel like a squirt, I put it in Sport. I've rarely used Race mode on bitumen and only a bit on dirt, but it really is noticeable how much drive goes to the rear.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  10. #30
    Jul 2014
    Quote Originally Posted by wfdTamar View Post
    It's your 'nice' car so you don't want to hoon in it on bitumen, but you're happy to hit the dirt roads hard enough you notice the grip difference? Something doesn't add up there, haha.
